Gentlemen, I am need of assistance. I am installing a new Auto Meter oil pressure gauge in an SRT-10 a-pillar gauge pod. This is an electric gauge and I have it installed in the pod in the truck. I have the sending unit installed and the wire run over to it, but not connected. Here is my question: the gauge instructions say to run one wire to the ignition so the gauge is only active when the switch is on. So where do I find the ignition wire to connect to? Should I find one coming down through the steering column and tap into that or is there a connection I can make out at the fuse center in the engine compartment? I thought I would check with the experts as I don't want to connect to the wrong wire and nuke the ECM! Geeze, the boss would be removing body parts!
Thanks for any assistance you can give, it is greatly appreciated.
