Installing Cab Clearance Lights
Sway Bars & Air Overloads
Am I nuts to think this?
Anybody out there done there own install of clearance lights? What can I expect????
2001 2500,AUTO QC,4x4,SWB,SLT PLUS W/LEATHER,HEATED SEATS,PWR ALL THE WAY,4:10 LSD,PERFORMER IAS, WARN,MAG-HYTEC DC&TRANS DD,TRUCK TRUNK BOX,KC,PATRIOT BLUE W/AGATE INT.
A fellow tdr member put mine on. The directions are easy and comes with a template to make sure they are lined up. On a thread about this not to long ago it was decided the worst part was drilling the holes in the top of the truck. I think the cost was 58. 00 and some change. Had everything in the box.
2001 quadcab slt 2500 HO 6spd. LWB,2wd,dk garnett red, trailer tow package,camper special, lock-right locker, 3. 54 gears,ez edge, speed liner,oversized stainless steel chicken slide,66 gallon in bed aux. tank,K&N air filter,Reese 20k hitch, Terry 2000 EX 30ft. double slide 5er, 2000 20ft gooseneck for haulin jeep, firewood and huntin stuff. 5X12 tagalong for haulin the 4 wheeler. Okie Newton
Steve,
Just did mine two weeks ago. The only problem I had was inserting the pin (for power) into the connector behind the fuse block. After trying to remove the connector (this must be done to insert the pin) for about 45 minutes with no luck, I removed the lower instrument panel brace directly below the steering column. This allowed me to get my head and hands in there to see what I was doing. I think there were six or eight screws. This should save you some serious aggravation.
I ended up not using the kit I bought from the dealer, but the instructions sure came in handy. I made my own harness and used Grote lights instead.
If you are interested in the kit, drop me an email.
<font color=forestgreen>2000</font> DODGE <font color=forestgreen>RAM</font>, <font color=forestgreen>2500 HD</font>, 4x4 SLT, Reg. Cab, <font color=forestgreen>Forest Green</font>, Agate interior, Cummins ISB, Auto, Shift-on-the-Fly (241HD), 4. 10 LS, ABS, Trailer Tow Group, Camper Group, Michelin; DC: Fog Lights Kit, Tow Rings, Under Rail Bedliner, VentVisors, Splash Guards, Cold Weather Cover, & Mats.
<font color=forestgreen>After-market</font>: JRE 4" Exhaust, Van Aaken, Practical Solutions Diesel Products:High Idler, Heavy Duty Idler Pulley, Intake Heater System Saver & HD U-Bolt/Anchor Plate Kit, Gatorback Belt, Painless Wiring, K40, Viper w/AutoStart, Clarion 6 Disk CD w/remote, UnidenCB w/Francis antenna, Draw-Tite Activator II, Alpex 255TC2C Air Horns, Continental BedRails, Delo 400, HOWES, Liquid Glass.
BigDaddy's Ram #ad
New England RamRiggers
<font color=36648B>2001 PT Cruiser Limited Edition</font>
Steve, At a little get together of cummins owner a little while ago, some folks that had installed their owner clearance lights said to just pull back the head liner and you could see where to drill the hole from the inside. No template needed. Apparently the brackets that the screws thread into served as a template. Haven't done it myself yet, just passing it along.
Tom
