Installing new injectors - Need help
acronyms
I drove a duramax
DD does send out a good set of instructions... you can also do a search and find several posts about this... one is Vaughn Mackenzie's...
The only thing I would suggest that is not on the DD instructions is to cut 1/4 of the side out of a 19mm deep socket forming a tubing wrench style of socket, it makes it a lot easier to get the injector tubes tight and you can use a torque wrench on them much easier than a crowfoot wrench. The DD instructions are complete and are very easy to follow.
99 2500 QC 4X4 AUTO SB 24V LARAMIE SLT 3. 5 LSD 285-75-16'S SPA Boost/EGT Rancho 9000's Everything but leather NRA Member Great Lakes TDR Member
The one piece of advice I can give you is to make sure you start at the injector closest to the front of the truck.
This way, by the time you get to that #$#@$ last one near the firewall, it won't nearly be so painful. You will have it mastered by then.
Shawn
Some more suggestion:
Be sure to protect the AC condensor when you're working with a piece of foam.
Also, might want to make sure you have a stubby 19 mm open wrench for injectors 5 and 6.
Charles
2000 QC 2500 4x4 LWB ETC/DEE, Anti-Spin, 3. 54, Trailer Tow, Camper Special, DD1's, PS boost module, PS high idle kit, PS steel idler pulley, Autometer boost and EGT gauges, Westin nerf bars, Rhino Liner
My Toy
1969 Toyota Land Cruiser FJ40
350 TBI, Turbo 400, ARB lockers front/rear, 4 wheel power disk brakes, 4. 88 ring/pinion, 3 speed transfer case, full roll cage, Warn 8274, MRT 36 bolt beadlocks with Super Swamper Boggers (16x35x15), Saginaw Power steering, custom bumpers/fenders/nerf bars/skid plate, GM tilt steering column, 6 point roll cage, RCI racing seats with 5 point harness. Conquered Tellico and going to Moab this May. Loves to be pulled behind the Dodge and pass the powerjokes going up hills.
I want to start out by saying "thanks" to all of the members that have helped with other mods in the past... . #ad
I am having DTT tc and vb installed this month, and I will be installing DDII's right after transmission upgrades. I have not done an injector swap before and I am hoping those of you with experience can help me out. Does anyone have a good set of install directions? I need pretty detailed info (torque specs, tools needed, parts needed, best way to go about it, and pitfalls to watch out for).
Any help that you can give is appreciated... If anyone wants they can email me direct at: dfsjetpilot@cs.com.
Thanks guys,
Doug S.
jetpilot
My DD3's came with a full set of install instructions (torque specs, tools etc ) you should have no problems.
jetpilot:
i put in a set of 275's about 2 months ago and still have the scars to prove it!! i had alot of trouble with getting the #6 injector line to align right to screw it back in. also, before you do anything, remove the rear engine lift loop!!!!! it will make your job alot easier. the job is very simple. just take your time and dont get fustrated. good luck... . james. .
1999 RED LOADED 3500 QC DUALLY. 331N. DUNLOPS,ALPINE AUDIO,PSYCHOTTY AIR WITH K&N,BANKS POWERPACK,275 injectors, VA CPC, soon come. . DTT TC and VB. more in store????
jetpilot , i have a suggestion , install the injectors BEFORE the DTT install , that way when the shop sets your shift points you'll be all set , adding the injectors after will land you back for another session , also make sure DTT knows your TRUE HP mods so they can set up your VB properly .
DTT APPROVED installer
H. O. , yes stop the cut at the part where the ratchet goes in, there is no need to cut any of the drive part of the socket and it will not work if you do. You are making a "crow foot socket" basically.
LSMITH, sounds good to me. I just wanted tobe sure of what I read. Thanks, Sam.
2001 RAM H. O. 6Sp 2500 SLT 4x4 Quad Cab, 4Wheel Disc, 4. 10 Limited Slip, Fog Lights, Muffler removed, Silence Ring Gone, Autometer Pro Comp 60# Boost & Pyro, Banks High Ram (Red), Cummins Red Valve Cover, K&N RE-0880, Skyjacker 2. 5 lift Class 2, 7218 Dual steering stabilizers, Custom Pro Fab Trackbar (sweet), EGR Flares (nice fit), Centerline Comet III 16x9. 5 with Goodyear MT/R 315/75R16, Smittybuilt stainless nurf bars, ExTang BlackMax tonno, THIS IS NOT A HOBBY, THIS IS AN ADDICTION !!! MAINLINING DIESEL !!! "I AM GLAD I DID NOT BUY AN AUTOMATIC, JMO"
Another suggestion that helped my install of # 6 injector was to buy a 19mm combo-wrench (cheap one from Pep Boys-$6)and cut it in half. It really was a tremendous help to get the injector line nut pre-tightened (no room for full size) before I used a 19mm crows-foot and the torque wrench to finish.
Y2K Awesome Black LB 3500 QC SLT, 24Valve ETC ISB, 4x4, 4:10 LSD, DTT Custom prepared Auto transmission VB, Power Edge 'EZ', DD2's, K&N, Polished Stull Billet Grill/Fog inserts, Chrome Smitty-Built Step Rails, Mopar Chrome-Tipped Mud Flaps, A-Pillar mounted West-Tach Turbo/Pyro/Trans Temp gauges, Rancho 9000's, Diamond Plated Tool Box, + a bunch of other stuff. Fact:The First Fords' had 'DODGE' Engines! The new PSD's need them!
DD instructions say to remove the throttle essembly bracket for removal of the injector line retaining bolt which resides just under the essembly. this essembly does not need to be removed. just remove the 8mm line clamp bolt just to the side of the essembly. much easier and less to take off and put back on. the rest of the directions were right on the money.
Good luck
2001. 5 2500 4X4, QC, Auto, 3. 54 LSD, SLT, SWB, Trailer, Camper & Snow plow Packages, White, 35k# Cody Hitch, 20' Gooseneck Lowboy flat-bed Trailer.
1975 Toyota Landcruiser, ARB Air lockers Front & rear, 400 Small Block, SM420 4spd, Stock LC transfer case with 2 or 4 high and 2 or 4 wheel drive Low gears, 15. 5x36" Radial swamper on 12" rims, Custom front & rear bumpers, Roll Cage, Warn 8274 8000# winch, 2. 5" spring lift, 2" body lift. Premier on-board power welder, on-board air, 4-wheel power disk breaks, power steering, Lot of fun.
LSMITH, I am planning on new Injectors in the near future. You say to cut a 1/4 slot in the side of the deep socket. Would that be all the way up the side just stop where the ratchet connects? TIA #ad
