Installing Prime Loc, soon.
KEENO rolls 200,000 miles.....
differential update
I recently purchased a Prime Loc relocation kit for my 92. Are there any sugestions on how to or what not to do during installation.
I noticed when reading the directions that there are 2 options, which is the easiest to perform?
Thanks in advance.
Jim
Just wondering why you are installing a Prime-Loc on a 92? The filter is super easy to reach. :D
Anyways, the Prime-Loc system has been the culprit of fuel system troubles on the 24V trucks... Not sure what its effects will be on the 92, but be sure to check your fuel pressure AFTER the filter before & after installing it. The VE pump relies 100% on fuel for lubrication and cooling, just like the VP44 in the 24V. To check your fuel pressure, use a fitting installed in the bleed screw in the steel line from the filter to the injection pump. Idle should be 6. 5-7 psi, and go down to around 4 under load. BOMB ON. :D
