All you need it to pop out the plugs on the grab handle with a small screwdriver, being careful not to mar the plastic (you have to reuse the plugs, or buy new ones). Next get a 10mm deep socket and remove the two bolts that secure the grab handle. The only difficult thing is weaseling it out of there, it is secured down by a couple tabs on the dash, and it pops up, but takes some force, it has to be pried up. Just be careful, and use lots of rags, and masking tape to make sure you do not mar your dash or anything else. You would be amazed at how easy it is to pull apart the interior in a Dodge.
