Attention: TDR Forum Junkies Mhannink said:well to me it seems pointless to throw money at the intake because the flow rating of the head is already less then the manifold. i dont see the point or making the intake flow better when the head is gonna restrict it to the same cfm as before. the exhaust manifold is simalar but there are advanagtes in turbo spool up by putting a different manifold. the only time i really think an intake manifold needs to be changed to a better one is if you have the restrictive egr on the egr 12v's
JFaughn said:It looks like carbon fiber , if nothing els your truck will faster becouse its lighter .
p-Bar said:curious on the head data where did you get that??
DrDiesel said:You can make all the intake casting design changes in the world, but the fact remains. The intake air passes through the same restriction on every truck with the CTD. The intake plate and heater grid. :{
Now if you changed that little bottle neck, maybe you would actually see/feel some major advantage.Maybe add a second port and grid off the inlet pipe onto the plate for a 1 on 3 x 2 type of setup.
