Integrated Power Module repair - '04.5 3500 cummins
Jumping Rail Pressure on startup
Grid Heater Light Comes on while driving
Has anyone out there ever disassembled the IPM so you can get to the internal circuit board? I can do circuit board repair .... just opening the plastic case is the problem!
thanks! ....
IPM #P05026032AB A
Before I reinstall the IPM/FCM back in the truck, I would like to wire-in a 'start/run' +12V for a set of LED Driving Lights (draws less than 1amp) ..... does anyone know an easy and SAFE area for this electrical connection to the bottom plugs(P1-P7) of the IPM? (P3/P4 are FCM inputs/outputs)
thanks
Looks like C5 Pin 15 should fit the bill
