Details here: TDR Privileges
I double nutted all of my boots & they haven't come off since. You tighten the first nut until it can't go no more, then the second nut will crank it down & hold them there.
Clean the boots & clamps with carb cleaner or brake klean, Clean the metal & plastic tube, scuff the tubes with 80 grit sandpaper, reclean the tubes, let dry. After three blow offs its held for 20,000 miles.
Not sure what year truck you drive but on my truck (99) it didn't come with the spring loaded intercooler boost clamps. After installing these clamps I have never had one blow off again. Tightened hand tight with a nut driver over 2 years ago & my problem was solved... . I too heard of the hair spray trick FWIW.
