Competition intercoolers/cfm
Competition Cummins and Banks go racing - 210 mph Dakota
Competition Dyno run results: PE Comp Rules!
anyone use aftermarket intercoolers or make thier own ? I was curious about the flow/ cfm to help get more air in faster. :confused:
Intercoolers
How about this for a question: Anyone used the technology of "liquid air" intercooling on one of our trucks ? I know the super go fast guys in some areas do this , I've seen the coolers being built first hand. Pretty impressive. I believe this form is mainly used to drop temp substantually, not to increase cfm. ---Proflow
speaking of liquid
well I found a TON of info on the excite search engine. too much to list ,but i will get a 24v cooler and seal it for 45 psi. and im gonna make a water spray inj system to cool the cooler as i pull on the hills and high egt moments. I figure 2 washer nozzles at each top corner to spary in front of the cooler just as my windshield washers do. simple and cheap.
washer pump,nozzles,3/16 hose. and a switch with wiring. ill let you know the results this summer. :cool:
Inject that water into your air intake stream (aft. intercooler) and watch the EGT's fall as well. It probably will reduce EGT's better than just spraying the IC with water..... the guys I have seen spraying their IC with water are doing it because they have very low surface area..... we on the other hand have plenty of surface area.
The air/liquid IC's are great for low pressure drop. Pressure drop is how much you loose across the inlet/outlet of the IC. Since many are cooled by iced water... . the ability to get some really low intake air temps is beneficial. Having yet another setup in my truck that has water/coolant and a pump is not appealing... . the less moving parts, the better.
There are even 'intracoolers' that use the refrigerant from the A/C system and make for intake air temps well below ambient at full boost on a hot day.
Since we are using compression ignition, I would think that intake temps that are too low would result in bad combustion and possibly low power.
Matt
On edit: BTW, Spearco is one of the most respected names in air/air IC's..... their cores are expensive and you usually have to buy the endtanks separately and weld 'em on yourself. Spending $1200+ on an air/air intercooler is not uncommon.
