Elite1 said:One thing you should note about the Chevy/GMC air filters (which is the vehicles being tested in this study), they have a better intake/filter system than the stock Dodge trucks have. They utilize a cylander type paper filter, not the flat filter the Dodge uses. Dodge owners shouldn't assume that this test has any bearing on our air filters. The old Apples to Oranges school of thought.
When I had my 96' Dodge TD, it came stock with a large air filter box and a large square filter. That truck had 160 HP. When I got the 03' the truck came with 305 HP, yet had a smaller air box and smaller air filter. I noticed after 10k miles, it was already getting restricted, pulling the filter minder down and hurting performance. IMO the engineers for Dodge did us a dis-service by downgrading the airfilter system instead of upgrading it! Chevy/GMC's come with a better air system than Dodge, I am sorry to stay.
steved said:I look at those results and find them very funny... notice that for the most part they are all within a persent of each other... the graphs make it look like one was clearly "better" than another... when they are all fairly close...
steved
TurboFan said:GECCO, 1 long week for you I bet!
congrats
GECCO said:Within one percent of each other?![]()
Accumulative Capacity
Best = 573. 9 grams
Worst = 196. 3 grams
The worst one only holds 34% as much dirt as the best
Accumulative Gain:
Best = . 4 grams
Worst = 7. 9 grams
The worst allowed nearly 20 times more dirt to pass
Initial Restriction:
Best = 4. 54 in of H2O
Worst = 6. 23 in of H2O
a 27% difference
Restriction to flow at 150 CFM (what our motors flow at their torque peak of approx 1600 rpm)
Best = ~. 25 in of H2O
Worst = ~. 75 in of H2O
a 67% difference
Those are pretty large differences..... however, the bigger picture that all of these tests paint is that you can have either good filtration OR good flow, but you cannot have both (assuming the two filters have roughly the same surface area). You can make a restrictive, "clean", filter flow better by increasing it's surface area (by fitting an intake housing that breathes through TWO or more filters at the same time), but you cannot make a "dirty" filter remove more dirt without sacrificing airflow.
Basically what I am saying is that their numbers indicate that if you fitted an airbox such that it breathed simultaneously through (3) stock AC Delco filters you would maintain the far superior filtration of the more restrictive filter yet simutaneously bring the flow rate to roughly the same as the K&N type filters.
Food for thought...
wmoody said:go to amsoil.com and click on product info and then click on air filters every thing including the testing (done by donaldson) is there for all to see!
