Read article from A John Deere publication, about "how to" destroy the diesel engine.
The argument is AGAINST turning up the pump (power). Tells the reader that this particular full sized tractor engine is designed by MANY MANY trained engineers who design the engine to operate at a given power level. The engine will do this and last long long time.
Goes on to say the engine piston (for example) is subject to 1050 psi and turning up fuel rate will increase to over 1800 cracking the piston. The added heat expands the piston and causing the rings to stick and score the cylinder walls. This also causes the engine oil to cook and turn into tar. Now, blow by allows fuel to enter the cylinder wall and wash it down. The engine is thus destroyed.
Continues to convey to the reader that there is NO SAFE METHOD to increase the power as the weakest link will fail and there is no such thing as a non weak link.
What do you guys think about the article? It does have some valid points. How often are the guys rebuilding the engine that operate under 4,5,6,700 hp????? Do they work for Cummins and thus obtain free parts or is the article full of bung?? Maybe JohnDeere engines are simply junk??? I always thought they are nearly the best engine available.
In short it relays to the reader that Joe Public is not qualified to pit himself against highly trained engineers, and thus CANNOT beat the odds.
GL
GL
