Interesting info (long)
PC at it's best
Cold Idle
Thought you might find this worth reading:
> "Real" Deal about Nuclear, Bio, and Chem Attacks
> Since the media has decided to scare everyone with predictions of chemical,
>biological, or nuclear warfare on our turf I decided to write a paper and
>keep things in their proper perspective. I am a retired military weapons,
>munitions, and training expert.
> Lesson number one: In the mid 1990's there were a series of nerve gas
>attacks on crowded Japanese subway stations. Given perfect conditions for
>an attack less than 10% of the people there were injured (the injured were
>better in a few hours) and only one percent of the injured died.
Forget everything you've ever seen on TV, in the movies, or read in
>a novel about this stuff, it was all a lie (read this sentence again out
>loud!)! These weapons are about terror, if you remain calm, you will
>probably not die.
> Chemical weapons are categorized as Nerve, Blood, Blister, and
>Incapacitating agents Contrary to the hype of reporters and politicians they
>are not weapons of mass destruction they are "Area denial," and terror
>weapons that don't destroy anything. When you leave the area you almost
> always leave the risk. That's the difference; you can leave the area and
>the risk; soldiers may have to stay put and sit through it and that's why
>they need all that spiffy gear.
> These are not gasses, they are vapors and/or air borne particles. The
>agent must be delivered in sufficient quantity to kill/injure, and that
>defines when/how it's used. Every day we have a morning and evening
>inversion where "stuff," suspended in the air gets pushed down. This
>inversion is why allergies (pollen) and air pollution are worst at these
>times of the day.
> So, a chemical attack will have it's best effect an hour of so either side
>of sunrise/sunset. Also, being vapors and airborne particles they are
>heavier than air so they will seek low places like ditches, basements and
>underground garages. This stuff won't work when it's freezing, it doesn't
>last when it's hot, and wind spreads it too thin too fast. They've got to
>get this stuff on you, or, get you to inhale it for it to work. They also
>have to get the concentration of chemicals high enough to kill or wound you.
>Too little and it's nothing, too much and it's wasted.
> What I hope you've gathered by this point is that a chemical weapons attack
>that kills a lot of people is incredibly hard to do with military grade
>agents and equipment so you can imagine how hard it will be for terrorists.
> We'll start by talking about nerve agents. You have these in your house,
>plain old bug killer (like Raid) is nerve agent. All nerve agents work the
>same way; they are cholinesterase inhibitors that mess up the signals your
>nervous system uses to make your body function. It can harm you if you get
>it on your skin but it works best if they can get you to inhale it. If you
>don't die in the first minute and you can leave the area you're probably
>gonna live. The military's antidote for all nerve agents is atropine and
>pralidoxime chloride. Neither one of these does anything to cure the nerve
>agent, they send your body into overdrive to keep you alive for five
>minutes, after that the agent is used up. Your best protection is fresh air
>and staying calm. Listed below are the symptoms for nerve agent poisoning.
> Sudden headache, Dimness of vision (someone you're looking at will have
>pinpointed pupils), Runny nose, Excessive saliva or drooling, Difficulty
>breathing, Tightness in chest, Nausea, Stomach cramps, Twitching of exposed
>skin where a liquid just got on you.
> If you are in public and you start experiencing these symptoms, first ask
>yourself, Are other people getting sick too?
> Is there an odor of new mown hay, green corn, something fruity, or camphor
>where it shouldn't be?
> If the answer is yes, then calmly (if you panic you breathe faster and
>inhale more air/poison) leave the area and head up wind, or, outside. Fresh
>air is the best "right now antidote". If you have a blob of liquid that
>looks like molasses or Kayro syrup on you; blot it or scrape it off and
>away from yourself with anything disposable. This stuff works based on your
>body weight, what a crop duster uses to kill bugs won't hurt you unless you
>stand there and breathe it in real deep, then lick the residue off the
>ground for while. Remember they have to do all the work, they have to get
>the concentration up and keep it up for several minutes while all you have
>to do is quit getting it on you/quit breathing it by putting space between
>you and the attack.
> Blood agents are cyanide or arsine which effect your blood's ability to
>provide oxygen to your tissue. The scenario for attack would be the same as
>nerve agent. The telltale smells are
>bitter almonds or garlic where it shouldn't be. The symptoms are blue lips,
>blue under the fingernails, rapid breathing. The military's antidote is
>amyl nitride and just like nerve agent antidote it just keeps your body
>working for five minutes till the toxins are used up. Fresh air is the your
>best individual chance. Blister agents (distilled mustard) are so nasty that
>nobody wants to even handle it let alone use it. It's almost impossible to
>handle safely and may have delayed effect of up to 12 hours. If
>you do get large, painful blisters for no apparent reason, don't pop them,
>if you must, don't let the liquid from the blister get on any other area,
>the stuff just keeps on spreading. Soap, water, sunshine, and fresh air are this stuff's enemy.
> Bottom line on chemical weapons;
they are intended to make you panic, to terrorize you, to
>herd you like sheep to the wolves. If there is an attack, leave the area
>and go upwind, or to the sides of the wind stream. They have to get the
>stuff to you, and on you. Your odds get better
>if you leave the area. Soap, water, time, and fresh air really deal this
>stuff a knock_out_punch.
> Nuclear bombs. These are the only weapons of mass destruction on earth.
>The effects of a nuclear bomb are heat, blast, EMP, and radiation. If you
>see a bright flash of light like the sun, where the sun isn't, fall to the
>ground!
> The heat will be over a second. Then there will be two blast waves, one
>out going, and one on it's way back. Don't stand up to see what happened
>after the first wave; anything that's going to happen will have happened in
>two full minutes.
> These will be low yield devices and will not level whole cities. These
>will be at the most 1 kiloton bombs; that's the equivalent of 1,000 tons of
>TNT.
> Here's the real deal, flying debris and radiation will kill a lot of
>exposed (not all!) people within a half mile of the blast. Under perfect
>conditions this is about a half mile circle of death and destruction, but,
>when it's done it's done. EMP stands for Electro Magnetic Pulse and it will
>fry every electronic device for a good distance, it's impossible to say what
>and how far but probably not over a couple of miles from ground zero is a
>good guess.
> There are lots of kinds of radiation, you only need to worry about three,
>the others you have lived with for years. You need to worry about "Ionizing
>radiation," these are little sub atomic particles that go whizzing along at
>the speed of light. They hit individual cells in your body, kill the
>nucleus and keep on going. That's how you get radiation poisoning, you have
>so many dead cells in your body that the decaying cells poison you. It's the
>same as people getting radiation treatments for cancer, only a bigger area
>gets radiated. The good news is you don't have to just sit there and take
>it, and there's lots you can do rather than panic. First; your skin will
>stop alpha particles, a page of a news paper or your clothing will stop beta
>particles, you just gotta try and avoid inhaling dust that's contaminated
>with atoms that are emitting these things and you'll be
> generally safe from them.
> Gamma rays are particles that travel like rays (quantum physics makes my
>brain hurt) and they create the same damage as alpha and beta particles only
>they keep going and kill lots of cells as they go all the way through your
>body. It takes a lot to stop these things, lots of dense material, on the
>other hand it takes a lot of this to kill you.
> Your defense is as always to not panic. Basic hygiene and normal
>preparation are your friends. All canned or frozen food is safe to eat. The
>radiation poisoning will not effect plants so fruits and vegetables are OK
>if there's no dust on em (rinse em off if there is).
> Finally there's biological warfare. There's not much to cover here. Basic
>personal hygiene and sanitation will take you further than a million
>doctors. Wash your hands often, don't share drinks, food, sloppy kisses,
>etc. , ... with strangers. Keep your garbage can with a tight lid on it,
> don't have standing water (like old buckets, ditches, or kiddie pools)
>laying around to allow mosquitoes breeding room. This stuff is carried by
>vectors, that is bugs, rodents, and contaminated material. If biological
>warfare is so easy as the TV makes it sound, why has Saddam Hussein spent
>twenty years, millions, and millions of dollars trying to get it right? If
>you're clean of person and home you eat well and are active you're gonna
>live.
> SFC Red Thomas (Ret)
> Armor Master Gunner
> Mesa, AZ
> Unlimited reproduction and distribution is authorized. Just give me credit
>for my work, and, keep in context.
I know I joined TDR for all the great information, but I had no idea that I would find this kind on site about CTDs.
Dang, this really was the best $35 I ever spent! :D
Thanks Ramboy... ... . GREAT INFO, It WILL be passed on.
Why won't the media give us info we can use, like this?:confused:
Thanks
Thanks for the info. We all need this information and will best serve our country by staying calm. I think it's time to do away with politcal correctness and flaunt our Americanism. If we panic and pull in our horns we are falling into the enemies hands.
Thanks RamBoy
Ramboy,
Where does VX fall into your categories? This is the one agent that I would be most worried about. Supposedly Sadam has this stuff, and if a few containers of this stuff make their way to the US (if they are not already here) and they are released in the the ventalation system of an office building or school, from what I have heard/read ... everyone is DEAD ... period.
Originally posted by FATCAT
Ramboy,
that would be unfortunate, however, you're still at a "one-building" scenario. there aren't many easily accessible buildings around that have a greater body-count potential than what we already lost on 9-11
And the public would still be even more pi$$ed than we are now!
(reiterating another point from the posting---delivery is not easy)
