BigPapa
I have had an interesting issue with my new-to-me '98 24V auto.
If I remove the Cluster B fuse from the fuse panel in the dash or drive the truck with this fuse removed, the tranmsission takes off in 3rd gear, will not shift into OD or TC lockup, fuel gauge doesn't work, and the alternator doesn't charge.
I don't have a scanner so to "fix" it, I have to disconnect the batteries for @ 30-60 minutes then drive the truck 2-3 miles up to highway speed, shut it off, and do it again and again, 3 times total. After this everythings back to normal. I feel like if I had a scanner to clear the codes I wouldn't have to do the previous procedure to reset.
I found all this out the hard way, from experience. The Auto Meter pyro that came in the truck, uses a fuse tap that was plugged into the Cluster B spot in the fuse panel. I removed it with the truck running trying to figure out why the pyro didn't work.
Can anyone explain this to me? I just want an answer, I don't plan on removing any more fuses with the ignition switch on.
Thanks,
Scott
Thanks,
Scott
