I bet coffee grounds would do wonders... if they claim teflon reduces friction, then caffeine should add at least 50hp...
steved
AH well ~ I've taken heat before for supporting the STP and K&N filters I have used with excellent results in past years... :-laf
On one newspaper press I ran in past years, we couldn't keep some of the open-running gears from failing prematurely - until I started applying STP mixed with powdered graphite - never had a single failure after that. I've had several mechanical items that were old and tired, and wouldn't operate with usual lubes - but took off and worked perfectly after use of STP.
Had several older work vehicles that used oil - one a quart every tankful of fuel - but oil consumption on that worse one dropped to 1 quart per thousand miles after STP - all the others did equally well.
Those, and more examples, are not anecdotal heresay, second or third-hand experiences, but my own...
Only downside in STP use, was when overhauling engines that had been using STP, ( yes, even engines using STP
WILL eventually wear out! :-laf) was that the STP actually penetrates the pores of the cast iron blocks - and it takes twice as long in a hot tank to get it out for reboring and honing the cylinder walls - or else the hones will get clogged and refuse to work.
I've had 2 different engines lose coolant, and get so hot the pistons seized in the cylinders - but after being allowed to cool, started and ran normally for many thousands of miles after that. THAT's where the STP does it's thing in preventing/reducing serious metal-to-metal contact damage. One of those engines, torn down for overhaul many miles and much later in time, showed absolutely NO internal effects of cylinder scuffing or related overheating damage,
But yeah, STP used in these later engines is probably a no-no, due to potential damage to catalytic converters and other emissions devices.
NOW, as to those nasty K&N air filters... :-laf:-laf
