Halo Light connection
I found an old email that I sent out long time ago on how to hook up the Halo Light. I will re-post for those interested:
I have a 2001 Quad HO 3500 and I found after opening up the steering column, that the light bulb was still present, just no wiring! The easiest way to reconnect is by running a pair of wires from the Halo light and tapping it into the dome light. Walla! Why the factory doesn't do this is beyond me. I'm sure that DC probably manufactured a million defected IEM's and was to cheap to fix the problem as my wife's Durango has the same problem.
Remove the top cover of the steering column. This is held on by three black torx screws found on the bottom cover (the silver one holds on the bottom cover). Once you pop the cover off it will be very obvious where the halo light lives (right above the ignition switch). The wires run from the lamp itself (a standard #74 if it ever does burn out) down to a four pin connector. Only two wires come out of the connector (the key "sense" circuit). Now extend the unconnected halo wires (black) by either adding the two missing pins to the connector or just splicing into the existing wires (like I did) with about 5-ft of wire. The new wires can be neatly run down the steering column and tie-wrapped so that it looks just like the factory did it. Route the extended wires up to the A-pillar by way of the fuse panel or up the door molding. I actually stick a very heavy gauge wire down through the side of the dash and pull the new wire up with it. Remove the A-pillar cover by just pulling it out enough so that you can work on the wiring harness and feed in the new wires. Unravel the black tape of the wiring harness about half way up the A-pillar. Center splice your extended wires into the pink and yellow wires found in the harness and rewrap the portion of the wiring harness with new electrical tape. Snap the cover back on and the halo light is all ready to go.
I rewired mine 1-1/2 [change this to 3-years ago] years ago (I received my truck in March of 2000 even though it is a 2001 HO model) and the circuit is working perfectly today. Never even a burned out bulb. One word of caution, however: whenever working on the steering column, be very careful with what you tamper with. I've been told that you can cause the air bag to go off. I personally feel that it would be quite difficult, but I thought that I would warn you anyway.
