INTERIOR PAINT
$ Cummins vrs Duramax $
The tingamajig
The 2001 just came in interior color AGATE ,we bought a can of mopar 82201339 code LAZ sprayed dual gage pillor mount 3 coats,it looks like primer color compared to the rest of the plastic in the truck. Is this the right part # ,or is there another # for the 2001.
It's about 3 shades lite.
THANK,S-
[This message has been edited by MACHINEST (edited 09-08-2000). ]
MachinIst... do a search on this topic, I always get flamed on this, but i had the same problem, If ya have access to spray equipment, go down to your local Dupont dealer and get there Vinyl die. Its as close to the factory as you can get... JB
99 Black/Agate, Quad,Long bed,4x4, SLT,Auto,HX-40 16cm2 & ATS Exhaust manifold treated to Jet-Hot 2000(Gray),DD stage 3 injectors,4 wire Blue Box,"True" 5 inch Jet-Hot Coated exhaust from turbo to Tailpipe(Over the Axle),Borla Shoot-out Muffler,Suncoast converter, BD valve body and pressure-loc,Mag-Hytec trans pan,Amsoil ATF-4,Mobil Super Delvac 1300,fuel line up-grade from lift pump to filter and from filter to injection pump,Auto meter Ultra lite gauges:Boost,EGT,Fuel Pressure,Trans Temp, Valentine 1, EZ-pass
I got a can from the Dodge dealer of interior paint "Slate Blue".
Perfect Match. #ad
[This message has been edited by HEMI®Dart (edited 08-18-2000). ]
At our local "True Value" hardware store, I found a can of "Dupli-color" , "vinly and fabric" paint that is to close in color match for me to tell the difference. Cost about $3. 00.
Vaughn
Just got spray can from dealer Part#4796190, code RC3, color is called Mist Gray, cost is 9. oo. Sprayed a pillar gauge mount and matches good. Tom.
Coolbreeze, the "Mist Gray" spray paint from Dodge may match the "Mist Gray" interior closely however, the "Agate" DOES NOT! I have witnessed at least 7 different cans (purchased at different dealers over a period of at least one year) of the "Agate", produce dramatically light results.
God bless you John, somebody knows what am talking about... JB
[This message has been edited by QuadDoorRam25004x4diesel (edited 08-20-2000). ]
