intermittant tapping noise
Do you need a clutch before I do??
Which auto trany is Best?
It's back, at lower rpms while moving I can hear tapping noise coming from the engine area and only at 1500 to 1800rpm. At a standstill I can rev the engine to any rpm and can't hear a thing wrong. I took it to the dealer and dragged the diesel tech out kicking and screaming for a test drive so I could prove to him there was indeed a strange noise. He agreed there was, but didn't have a clue what it might be. Truck spent the day at the dealer and the mystery noise is still that. I think it's in the pump but why can't I duplicate the noise unless the truck is moving? strange.
Check your transmission tower. Pull the boot and use a mechanics stethascope. I found mine was the gear shift rattling. But sounded like a valve tick!
Denny
'99 2500 4X4 White short Q cab to much added to put here
On Order- Mom's Ram 2001 Qcab CTD with auto trans and all the bells and whistles
Before thinking it is the engine, jump or push the front bumper up and down so the front end cycles. Check the outer sway bar ends for a loose link. Mine had one loose on the driver's side. Drove me nuts as I was wondering what was going to break, until I had found the cause.
99 2500 QC longbox, SLT, 4x4, 24V Cummins, 5 spd, 3. 55 LSD
