Engine/Transmission (1998.5 - 2002) Intermitted Start on 1999
Engine/Transmission (1998.5 - 2002) 1998.5 24-valve won't start
Engine/Transmission (1994 - 1998) where is the oil going
I have a 1999 Dodge Ram 2500 4X4. At the moment the truck starts when it cold / hot every time. When the truck is driven 30 - 40 minutes and then when it is left sitting for 20- 30 minutes the truck will crank but will not start. I have check the following when it would not start:
1) Swap the ADC relay - no luck
2) Verified that fuel is coming out of the lift pump when it is on - it is
3) Verified fuel is present at the banjo fitting at the VP44 pump - fuel does come up when the lift pump turns on
4) Verified the VP44 pump had 12 volts - it did
5) Verified the VP44 pump had a good ground - it did
After the trucks sits another 40 - 90 minutes it will always fire up. It does not run rough when it starts. At the moment everything I have read indicates it is the VP44 pump. Is there anything else that I could check before spending $ 1,050 plus? What other device could come into play. In closing this truck was just at a Chrysler dealer and they said it only showed a APPS code but could not verify the APPS to be faulty? Also when driving the truck the RPM rev's up very slightly. Any and all help is appreciated
VP might be going... . am going through this right now... . sounds like the same thing that happened to me... ... . it sucks... . god speed and good luck... . btw... any codes?
It may sound hokie but star would have you pour cold water on the vp to confirm pump failure in cases like that
i am having the same problem. thats the way mine started and now the truck only starts every so often. i have done all the tests u have. i just havent had the $$ to fix the truck. but every thing ive read has said its the vp. could it be the ecm??
