I recently installed an inverter and I tied it into my passenger side battery. Everything worked fine for a while, then I noticed the "check gauges" light illuminated, and my voltage gauge went to 0. Obviously, I was not charging. I immediately turned my truck off to investigate. I could not find any shorts. When I started back up everything was fine (charging normally). This happened a couple of times, so I just disconnected the inverter from the circuit. All is ok. Anyone have an idea as to what is happening? I am guessing this is some safety circuit to prevent damage to alternator diodes?? Anyone experience this problem? Thanks, Bill
