Hey guys!!
Its been awhile since I have been on here, and I have been searching threads today trying to find similar issues. Here is what is going on.
Randomly, when I actuate my power windows from the drivers door, either driver's side window or passenger's side window, all hell breaks loose, electronically speaking. When I hit the window switch, the ABS light, BRAKE light, and Airbag light come on, the blower fan stops, and the speedometer stops. Assuming I stop touching the window switches, it comes back to life in around 5 seconds or less with no lights on anymore. This randomly happens, so it doesn't happen every time I use the windows, and it doesn't stay on or have lasting effects.
I have pulled the rubber boot off that goes between Drivers side door and cab to look for bad wires with no luck. I next pulled drivers side door panel off and un-taped the harness to look for shorts, cracks, wear spots etc, with no luck at all. Everything looks perfect!!! It sure seems like something is shorting out somewhere but I can't find anything. Could it be the PCM causing problems??
What do you guys think?? I have a trip coming up in a few weeks of about 2000 miles, and really hate this intermittent problem!!! Any help is greatly appreciated in advance!!!!
Kevin
Kevin
