Hey yall.
I have an 06 Ram 3500 4x4. New drag link, ball joints, pitman arm all recalls and 08 steering upgrade. I had drag link replaced last. Said an alignment was done.
Got truck back, had a pull to left.
The last time this happened, I had another alignment done at an “old school” shop and it fixed the pull. Tried that again. This time it didn’t fix the pull. The pull is slightly intermittent though.
I do a visual inspection and see that my steering damper is covered in grease. Undo the end and check if it extends again, and it’s toast. Why no one under the truck told me the damper was covered in grease and dead is beyond me,
I assume this is what was causing the pull since everything else has been replaced. I order a Bilstein replacement.
It’s in today. I’m holding them next to each other and notice the Bilstein is a couple inches longer so I assume it compresses to the correct length.
Now that I’m looking at it though, it looks like the damper pushes to the left. So if I put this new one on, Will it make my left pull worse? Do I have to install and then get an alignment? Is there anything I need to adjust to correct this left pull?
