Howdy! I have a '98 Ram 2500, 24 valve ISB, 5 spd, 2WD. My problem is a long term intermittent that is getting to be regular. When I go to start the truck it doesn't want to cut the lift pump on. This used to be a hot start problem but will now do it at any time. You go to start the engine and it won't start, let off the key from start to run, wait 5 seconds and the pump cuts on, pressure rises and then the engine will start. When it first started screwing up back in January I checked the pump pressure and it was low so I changed the pump. The problem tapered off and then returned with a vengeance. I re- checked the pump and it had wildly varying presures so I hung another one, pressures are steady but I still have the starting problem. I've checked powers and grounds, all seem OK. When the pump cuts on there is instant pressure so I don't think I have a drain back problem. Truck had a PO1693 and a fuel sender code, the sender was broken way before the problem started so I doubt it's related. Snappy shows the pump is running when it is demanded by the computer, for what ever reason the computer is not cutting it on when it screws up. The engine starts instantly with fuel pressure and runs and drives well with good fuel economy. Anybody have this happen before?
