Basics - - 94, 160 pump, 0 plate, 4kgsk, stock injectors + DV's, 190k
This started awhile ago but it is getting more and more frequent. From 1. 7k+ rpms i get a complete miss from one cylinder that i can hear easily out the exhaust and feel, not a slight miss, a cold cylinder miss... .
It will do it sometimes just cruising but usually does it 90% of the time during a WOT burst
It is like someone flips a switch when it happens too, like on and off, it runs flawlessly when it is not missing but then it will snap into a miss for a few seconds and then a few seconds later come out of it...
I was thinking it was just air but i have bled and rebled, so that is not it
Fuel press is good
sidenote... . when i first installed the 4kgsk it would breakup above 3k in neutral with a #5 plate... ..... then i switched to a 0 plate and it runs clean to3. 5k+ with no breakup at all now
I am hoping it is just a sick OEM injector causing this, as i am saving for a set of DDP's, and not the pump?
any ideas?
thanks zac
Fuel press is good
any ideas?
thanks zac
