I've got a 99 4wd automatic that is giving me a headache. It all started two weeks ago, I was driving normal and came to a stop sign, and when I went to pull out it was in second gear. I got to where I needed to be and tried it again from a stop, and same thing, in second gear. I put it into first with the shifter and it went into first gear. The truck sat for a few hours, I got in and threw it in 'D' and it actually was in first gear when I pulled out, and it worked normal for the entire drive.
I checked the fluid, and the level was perfect and it looked good, didn't smell bad. About 5000 miles ago I put a Dodge filter in when I put a deep Mag-Hytec pan on. A friend of mine used to work at a Dodge dealer, he took a look at it and the only thing he noticed was the cable from underneath that black plastic cover on the front of the engine that goes down to a little lever on the trans was out of adjustment, and when both ends were disconnected he said it felt funny when he would move the cable. So, I ordered a cable from Dodge and we put it in and adjusted it.
I was driving the truck a few days, and the only thing that was not right to me was after that was it would hang real long in first gear when first being driven after starting it. By real long I mean it would shift around 22-2300 under normal light throttle, and when it would shift it would really snap into second gear. Someone recommended I put a bottle of Lucas Stop Slip in to help 'soften' the seals, so I did and have been driving it to see if it clears up.
And now today I was driving for a few miles, got off the highway and came to a light, and when I pulled out it was in second gear again. It did that several times. I stopped, and it sat idling for 5-10 minutes, and when I went to leave it was ok again.
So I have no idea what to do or look for. My friend told me it probably needs a trans, but I really don't want to believe that. Anyone have any ideas on what to look for or what it could be? I would like to check or do as much as I can before I drop it off at a transmission shop.
