Hey Guys,
Been reading through all of the "rough idle" posts and I am pretty sure that my issue is a failing FCA, but not all of my symptoms match up perfectly. Truck is an '06 with 99k miles... A few months back I noticed an intermittent rough idle at start up. . Idle smooth as silk for a 15-20 seconds, then rough and lopey for 5-10 seconds. . I noticed that the rough idle corresponds directly to voltage drops on the voltmeter (assuming when the grid heater is kicking in). . Voltage drops, rough idle, voltage returns, smooth idle. . After maybe 3-4 minutes of this cycling, the truck smooths out and idles just puuurfect. . Is this symptomatic of a crapped out FCA? I did have one single episode of white smoke on a cold start up after the truck had been sitting for several days, but it is not consistent. A while back it went through a phase where is would go into limp mode and throw a code (cant remember the exact one) but it was something about a fuel system short, and the research I did at the time led me to believe it was likely needing the valve cover gasket and injector harness replaced. .
Looking forward to your insight... Going to purchase a new valve cover gasket/harness and FCA (known failure item anyway) but want you guys input on if there may be other issues at work here. .
Thx
Thx
