The OEM disc pads would squeel at just about every brake application. Finally I changed them, got tired of the squeel. Was very careful to make sure the place on the caliper where the new pad backing supports rode were clean and smooth. Put the pad retainer clips back on just as they were origionally.
Now at times, no pattern, sometimes just riding straight ahead, sometimes turning left or right the pads come in contact with the rotors (rotors were turned when I replaced the pads) and start a light squeel until I tap the brakes and it will stop squeeling. I do not want to warp a rotor because of a pad riding on the rotor.
New brakes have been on about 500 miles.
When I had the calipers apart I used caliper grease and greased the caliper pins.
I am going back into the brakes today or tommorrow prior to a 2500 mile trip to see if I can correct whatever the problem is.
Ideas?
Bob Weis
Ideas?
Bob Weis
