Interresting new Water Separator.
Couple of 2009 Questions
FASS or AIRDOG
:-laf That's the same one on the bigger Case excavators! The SWK2000-18 looks like the right one. After reading about it on their site, it has huge ports. Pretty sure the Case ones are 1/2 or 3/4. Same style though.
Austin, didn't see any heater options, just WIF sensors.
This design is quite common on heavy equipment that live in the woods and sit out where if the water freezes it plugs up the works...
All Class 8 trucks with air dryers on them also have a heated circuit to keep the water liquid until the dryer purges it out... .
Guys I talked to the FASS tec guy, he stated that the sys he has is a pressure side 3 mic filter and suction side water sep. The water side is the key to what all the folks I have talked to said "should be on the suction side to most effectivly and easely seperate water". The sys has a pump filter and water sep all in one pakage, mounted to the frame rail, with jumper wires so no splicing. I may just use this insted of the new TSB. Genos has if for about just under $600.
