My sisters 99 24v is having some dead battery issues. I hooked up a clamp meter to the positive clump of wires off of the batteries. With everything off, doors closed etc there was about . 8 or . 9 of an amp draw. I pulled every fuse and relay in both locations with no change in amps. The only reason I ask this is because just recently her radio started staying on, even with the ignition off and key in her hand. Not sure what is going on there, but when I pull the radio fuse, I only drop about . 2 of an amp. So I put it back in... ... ... ... . she needs her tunes. LOL Fired truck up after boosting for about 20 minutes and everything seems fine. Alt was putting out about 80 amps and charging @ 14+ volts. The batteries were new NAPA ones that I put in about 4 months ago.
