I guess this is the "price" of having an overdrive in my truck...
Some may remember that when I had my '96 RAM, I had the Aerotanks 60 gal tank in it. Well, I kept that tank when I traded the truck, with the intention of putting into the new truck.
Today, I finally took the time to approximate what would have to be done to the tank to make it fit on the truck now that my US Gear Overdrive is on it, which has caused the transfer case to have to move aft 12".
It means the front 10" or so of the tank will have to be cut off. Doing the math, that works out to about 10 gallons of fuel capacity I'll lose.
Also, given that the only guy I trust to do this work is a bit pricey, I'm estimating the cost of this work, plus installation, to run around $600.
That means the cost of adding 15 gallons of fuel capacity will be about $600. I'm debating if it's worth it.
Maybe it is, since this thing still isn't getting crap for mileage. Get this... with my Lance camper loaded (total truck weight right at 11k), running 65 mph with the cruise control on from Concord to Santa Clara, and back, the best I could get was 11. 8 mpg. Unreal. If I hot-rodded it, I'd get 10, but I figured if I took it REAL easy and suffered through the incredible boredom of "behaving," I might do better. But nooooooo. This super-fuel-efficient ISB (yeah right!) isn't doing crap for mileage. Yeah it only has 5500 miles on it, but as much weight as I've been lugging around from time to time over the past 3000 or so, you'd think it would do better than that.
Okay, so that's more of a rant, but still.
I should go out and take exact measurements, maybe see if we could avoid cutting the whole tank off across the front... maybe notch it or something. The key is to be able to still pull the xfer case (if it's never needed) without having to drop the tank. Still, I figure best-case, I'll lose at least 5-8 gal. And the more fancy welding he has to do, the more it'll cost.
Meanwhile, what could I get for the used tank? I paid almost $700 for it (shipped), I'd hope to be able to get $500 for it if I were to just sell it.
Rob
2001. 5 RAM 3500 QC 4x4 ETH/DEE Silver/Agate 4. 10 USGear OD, Rickson 19. 5 Wheels, Edge EZ, SPA Guages, Psychotty, Firestone Airbags, Hellwig Rear Swaybar, Torklift Superhitch & Camper Tiedowns, Mag-Hytec Diff Cover, DD 4" Exhaust, US Gear Exhaust Brake, etc.
Rob
