Is 4000 miles to short a life for fuel filter?
WOrst fears realized--sort of
Over Preasure,can It Cause...
I actually already know that 4000 miles is to short a life for a fuel filter but help me out here. I drove 500 miles to Myrtle Beach week before last and the truck pulled great the whole way. I get to the campground and unhitch and park the truck, next time I go out to start it it idles like crap. Shaking and surging, even dies once, so I figure it's the air or fuel filter so I change the air the next day but no help. Next it's the fuel filter and it helps a lot but not completely. The next day I decide to pull the new filter back out and check for dirt in the canister. Sure enough there is dirt in the bottom of the fuel bowl so I take a rag and clean that all up nice and shiny. It still idles a little rough once I got home until I bought a 1/2 tank of diesel from a trusted source and added Power Service to it. Now it runs fine.
Now to the reason I'm even posting this. Should I be looking at adding a secondary fuel/water separator filter system? Do you think there could a build up of dirt in the fuel tank that needs to cleaned out? Since I know 4000 miles is way to short for a filter there must dirt getting into the system from somewhere.
Any ideas????
Bill
jjdiesel, yeah that's what I've started looking at was their separator combo unit. Do you have one and does it make a big difference?
Scooby, that's why I hate buying fuel on trips. you have a good source around home but when you're out it's a crap shoot. That's why I'm wondering if a secondary filter system wouldn't be a good idea?
The stuff GDP sells is great. I have their 2 mic setup underhood with a Cat filter, and my own homebrew extra f/w sep under the cab...
Can have too clean a fuel at 2xxxx psi
I saw your install photos from one of the other Cummins site, real nice setup. I'll have to put both of mine underneath since I have the APPS under my horn. Did you keep the OEM filter setup intact or have you removed it completely? I noticed that GDP sells a pass through to remove the OE filter but didn't know if it was worth doing. What filters besides the Fleetguard fit on the GDP setup?
I am continuing to use the original 10mu fuel filters in front of the 2mu GDP filter because I 'believe' the 10mu is a better water separator than the 7mu filter. Change the large 2mu filters every 3rd regular filter change.
4000 miles, try 90 miles
I got ahold of a bad batch this summer and was only getting 90 miles per fuel filter. Went thru 9 of 'em before all was well again. They were so clogged, you couldn't blow air or fluid thru them. (i tested all 9 of them).
Tony
