I actually did a lot of research on the FASS & Airdog before going with my Glacier. I just spent some time hunting around for one of the threads I remembered reading and found this:
https://www.turbodieselregister.com/forums/showthread.php?t=89707
If you read all the way through it, you will find two separate sets of 3rd party dyno numbers on a 2nd gen. One claims 0 HP for the FASS, and one claims 10HP. You will also find a lot of interesting commentary by the inventor of the fuel/air separation system, Charles Ekstam. If you aren't familiar with the story, Charles is the father, and his company sells the Airdog. Brad Ekstam is the son, and his company sells the FASS. Back in 2004, Charles sued Brad for patent infringement, but I never heard how it came out.
Also, as near as I could make out from Charles comments, there are two supposed benefits of the FASS that I would like to comment on:
1) Reduced cavitation. Cavitation seems to be the presence of a vacuum on the trailing edge of the pump impeller/piston produced when the pump is unable to draw in sufficient fuel. The FASS claims to eliminate the vapor caused by cavitation, but it seems to me that this effect is due more to installing a bigger lift pump that can supply more fuel to the VP44 or CP3 than due to any fuel/air separation function. As far as cavitation induced in the lift pump itself goes, if I read Charle's claims right, he seems to believe that the Airdog's design filters out any vapor produced by cavitation in the lift pump, and that the FASS design doesn't.
2) Retarded injection timing. In the thread above, Charles said this was because any air/fuel vapor in the injection pump cylinder was compressible, so that as the injection event started, there was a slight delay while the air/vapor was compressed before the fuel/air mixture entered the cylinder. I really don't think this applies on a common rail engine because the fuel/air vapor is already compressed in the rail, and if anything the decompression as it goes from 10,000 psi to 500 psi will force the fuel/air mixture out in a manner similar to the way CO2 forces Coke out of a shaken up can once it is opened.
In summary, I think putting a Glacier, FASS, or Airdog on your truck is a great idea, because they all seem to be good at their primary job of getting fuel to the injection pump. Most of the owners of all 3 systems seem to be pretty happy campers and many seem to be quite happy to defend their chosen product religiously. Factors I would look at are performance, reliability, filtration, and noise. The benefits of the fuel/air separation function itself are highly debateable for the 2nd gen and 3rd gen trucks.
p-bar,
I think you missed my point. If you have 10% entrained air in the fuel tank at 14. 7psi (sea level pressure), and compress it to 10,000 psi in the fuel rail, then since the air compresses and the fuel doesn't, by volume you only have . 015% air in the fuel. So 99. 985% of the fuel that is supposed to be injected into the cylinder is. If you are concerned about that last . 015%, then by all means get a FASS. Diesel engines are designed to run lean. Extra air in the cylinder isn't going to do anything other than help the fuel burn better.
