I am running amsoil in my 2008 2500 and am wondering if anyone knows how it compares to others? Is it better and worth the price
Only you can decide. In my opinion it is not but I only speak for myself. I use conventional motor oil.
The owner's manual and all written and spoken information from Cummins always stress that use of synthetic oils does not change the oil change interval so how does it benefit you?
the oil changed at the dealer every 3K. It's cheap insurance on a $10,000 motor .
Its definately worth the price if you are using it for your front and rear axles.
I use it in my I/O outdrive and noticed that the trans shifted into gear way smoother (less chatter) than with the OMC dino gear oil. Also, since I only run the boat engine approx 20 hrs per season, I can extend the drain/refill over a few seasons...
I know its a little off topic, but their gear oils are great.
Every 3000? I am changing at 5000, forgot to get sample for analysis, but will on next. Manual says 7500, but that seems long.
Geno's has a couple of different drain plugs, I was looking at the one that has the nipple for the hose to clamp on to.
What are you folks using?
