rivercat said:how do you stand the hx-35 with 4s-dragcomp ?
rivercat said:Getting ready to buy a Drag comp and tap the pump. Is it worth the extra 50 to use the pump cover or just tap the wire? Whould it be better to trade the M4s for M6s and forget the comp or just run the 4s with the comp. What is the difference on a ETH ?
rivercat said:they way I take that is, and correct me if im wrong vendors. Is 4. 5 is the biggest you can run with a comp on 5x5. Without the comp you can run 6s to make up for the other 70-80 you lost not running the tap on the comp wide open.
rivercat said:Is it worth the extra 50 to use the pump cover or just tap the wire? Whould it be better to trade the M4s for M6s and forget the comp or just run the 4s with the comp. What is the difference on a ETH ?
