I was down to the Ram dealer the other day and ran into a guy I know who has been there over 10 years. He said that a 1500 Ecodiesel with 9,000 miles on it is in the shop with a
cracked block. Said they are waiting for replacement engine, probably have to take one off the assembly line. Might be an isolated case but food for thought.
VM's main business was/is industrial and commercial engines. I'm pretty sure they will hold up just fine.
I went online to school myself; I'm old enough to know that any thing with chain drive will require $$$maintenance. Com'on man two chain driven cam shafts, spells nothing but $$$ down the line. Not to mention chain failure and what that can do to the rest of the engine; remember that old bicycle you use to ride? Might be ok if you own a Masarati and you have more $$ than brains or just in it for the prestige. I think I'll not get caught up in the heat of the moment and take a back seat for now.
Without any knowledge on the VM motor, being all aluminum, you can expect normal wear any standard gaser engine would have. I would expect 150k before problems show up.
