Every 7 - 10 years I pop out the snap ring or retaining clip on my ratchets to clean the metal to metal surfaces, and apply some bearing grease to the drive mechanism--body teeth,directional mechanism, drive teeth, etc. I don't pack the cavity like I would with bearings, just a liberal amount to make sure everything is lubricated and any excess grease has space to be displaced. BTW, my friends look at me like I'm crazy when I do this, but I've messed up the teeth on cheap ratchets before. New ratchets are bone dry inside from what I've seen.
But I've never done this with a torque wrench. I don't think it would affect the accuracy, because the torque components are in the handle. But because it is a calibrated instrument I've never messed with it. It also uses the flat, spring-like retainer ring to hold the drive mechanism in, which isn't as easy to remove and replace as the snap rings are. The torque wrench I have is a Craftsman, model 9 44542. Any problem greasing the drive mechanism on this?
Thanks.
Thanks.
