per gallon to get Valvoline PB Extreme http://www.valvoline.com/pages/products/product_detail.asp?product=103 there spec sheet... .
Help these specs are confusing to say the least - for example compare Viscosity @ 100 for PB of 14. 7 vs 15 for Shell..... there are other examples but I don't know what they mean... ... i. e. which way is better???
Typical Properties 5W40
Viscosity @ 40 C, cSt 89. 4
Viscosity @ 100 C, cSt 14. 7
Viscosity Index 172
CCS Viscosity @ - 30 C, cP 6300
Borderline Pumping Viscosity @ - 35 C, cP 17. 300
High Temp. High Shear Viscosity @ 150 C, cP 3. 9
Pour Point, deg. C -39
Sulfated Ash, % 1. 6
Total Base Number (D-2896) 12
Foam / Aeration Tests Pass
over
Shell ROTELLA® T http://www.rotella.com/products/index.php
THeir spec sheet... .
Typical Properties of Shell Rotella® T Synthetic
Test SAE Grade
Method 5W-40
Product Code 54300
Viscosity:
@ -30°C, cP D 5293 6400
@ 40°C, cSt D 445 90
@ 100°C, cSt D 445 15. 0
Viscosity Index D 2270 176
Flash Point, °C D 92 222
Pour Point, °C D 97 -40
Low temperature cranking viscosity
cP @ -30°C
D 5293
6400
Low Temperature Pumping viscosity,
cP @ -35°C
D 4684
39,000
Neutralization No. TBN-E D 2896 11. 5
Sulfated ash, wt% D 874 1. 47
Handling
Viscosity Index 172
over
Test SAE Grade
Method 5W-40
Product Code 54300
Viscosity:
cP @ -30°C
D 5293
6400
cP @ -35°C
D 4684
39,000
Handling
