otis, like TNT stated, best bet is to check the fuel pressure. If you plan on have having the dealer check it, be warned, what they see may not be what is actually happening. These pumps don't just die, they go out slowly. If possible, hook up a temporary FP gauge and go for a ride. If you see good psi's at idle or under throttle at idle, take a short trip and test it under a load. A failing pump will show sporadic readings and you will actually see the FP gauge needle jump around, in my experience. If your pump is truly dead, you will experience hard starts and a very pronounnced bucking/shudder under heavy throttle.
Scott W.
