I installed the latest greatest version of the stock lift pump earlier this year. Everything has been great with 14-15 lbs of pressure at idle and around 12 lbs driving down the highway.
This morning on my way into work, I noticed my guage had dropped to 6 lbs!!! Plus it seemed to be dropping slightly the further I drove. Since my fuel light had come on the day before, I thought that maybe my fuel guage was stuck and the pump was sucking air and I was really lower on fuel than I thought. So I stop and refill the fuel tank (took 28 gal).
When I restarted after filling, the pressure was back to 14-15 at idle and everything seemed okay.
A couple blocks later while I was watching the guage, it suddenly dropped from 14 lbs to 6 lbs! Just like someone had flipped a switch or something. I continued on to work with the pressure returning to about 6 lbs at idle and running around 4 lbs.
A few blocks from work I pulled over and shut the engine off for a couple seconds. When I restarted the pressure was back to normal. I was only a half mile or so from work and the pressure stayed normal until I got to the parking lot at which time it again dropped to 6 lbs!
Fuel filter was changed about 10k miles ago.
I don't think the lift pump has more than 10k miles on it. I don't remember now exactly when it was I changed the lift pump.
The auto meter electronic fuel guage has been in place for over a year with no problems.
To make matters worse, I need to pull a trailer 600 miles each way this weekend, so need to figure out my problem in the next 24 hours.
So... ... has anyone else seen this behaviour and was it a failing lift pump? Or could it be the guage or fuel filter causing this?
