So I have been trying to figure out why my EGTs climb so slowly now with te new EDMs and timing adjustment. I hav figured that my timing is set between 15 and 16*, but not sre cuz of the variances I got but according to the dial indicator I never got above 5. 6mm lift reaching TDC, so it as to b close to 16 and definatley around 15.
Anyway, does that much timing really decrease the EGTs like so? I only see maybe high 1300* when hammering on it, but can see higher when hammering on it from second gear instead of third. BTW, when is a good time during acceleration to rate my EGTs? Full, hard accel from a dead stop or just a couple gears of full fueling? I have always been confused about this.
Smoke is still there, obviously from the pics I posted, but it clears up good after 2K rpm. I won't have time to double check the timing setting till this weekend, but what do you guys think from my exhaust temp data, too cold? Cruising down the freeway I am still getting 750-950*F, please let me know if there is any other data you would like to hear to determine if the timing is advanced too much.
Thanks guys,
Joe
Thanks guys,
Joe
