is my truck an 03 or 05?
drive shaft bolts torque spec.
San Antonio, TX,...who is the perferred performance shop for CTD??
Have an 03, 3500, 6sp. Injector stuck open washed out #5, found an 05 engine on ebay, installed it, everything works fine. QUESTION: when i buy boxes, programers etc, do i buy for an 03? [ my comp, :confused: wiring harness, etc] or an 05, i'm pretty sure i buy for an 03 but thought it might make an interesting topic. james
Which ECM and wiring are you using?
Bob
Thats a hard one cuz if you use the 05's ECM it may not communicate with the BCM properly, I wouldn't even try to go that route.
On the other hand if you use the 05's injectors with your 03 ECM it may not fuel properly cuz those 2 are not matched either but is better than the other IMO.
From there on you would buy 03 HP stuff.
