My truck has been stumbling at different times over the past few months. The poblem comes and go's so It has been diffucult to pin point. At cruising speed I will lose all throttle response, pump it a few times and it comes back. Thought it was the waste gate so I blocked that off and the problem went away for about a month, now it is back but much worse, I also recnetly changed the TPS with no luck. I have unplugged my tapped wire for my DDUFM/edgecomp, and turned off my commander. Truck starts fine, idles fine, there is a loss of power. I have 15psi idle and 13cruise with my LP set up. My LP has died in the past but usually caught it right away and changed pumps. This problem also increases up hill especially towing 5er. Thought it could be heat related because when it was happening in the past it was 100 out, now it is only 40-50's. Any input would be greatly appreciated, and also the best aftermarket VP opinions. I have done a search just want fresh input Thanks TO ALL. Later. Sorry I posted twice, incase some dont go to 911
