Filters are more important than the brand or type of oil you use. Filters are critical including the air filter that keeps the dust out of the $10,000 engine. Fuel filters are protecting a $3500 set of injectors, what warranty. (Voided by bad, wet, or dirty fuel.) Filter performance like
@JR mentioned is one thing most take for granted, but, it's the most important criteria. (Not cost. Cost doesn't mean a good filter.)
Some oil filters don't last more than 3000 miles like Tear-O-Laters before the filter media fails. Others, well you would be better off with a t-shirt stuffed into a can, than the defective manufacturing that leaves a pleat unglued and wide open. (As I found on an expensive top of the line Mobil oil filter. No, The FRAM Group that makes it didn't care when I told them about it. High cost got me a garbage painted filter can.) Point of fact: a defective oil filter can kill the Cummins engine by the filters own debris from falling apart plugging the piston cooling jets. Then you get to argue with the claims department of the filter company like one member here did when a OCOD Fram took their 6.7 out.
7500 miles is a lot for a filter as well as the full 15,000 miles. Some oil filters simply won't last that long.
None of the filters you mentioned are subject to to the above problems, however, better filtration means longer engine life. My point is there are worse filters out there. End of the day the company standing behind the filter is important for the rare claim, but, more important for quality control and meeting the published specs.
Put the best filters on it by specs not cost. Save money by running the full time (1 year or 6 months per your owners manual) and the max miles. Modern oil can go the distance specified in the owner's manual. At $100 or more per oil change one should look real hard at any reasons they need to change the oil sooner.
