I have 96 dodge ram 2500, 4x4, cummins 12v, auto transmission, and the PCM is showing an ECT high code, and the truck will not shifting into overdrive after it runs for a few minutes. I have checked all the usual stuff like TPS and the only thing I can find is this over temperature code.
The problem is the 96 engine only has one sensor, and the wiring diagram I got from Alldata does not show it is connected to the PCM. So is this code valid and if so does anyone have a wiring diagram that shows how the sensor is connected to the PCM?
Help
Jim
Help
Jim
