There are two bulbs. The OD switch lighting runs off the same fuse as your dash lights, the dimmer circuit, if it's blown you will have no dash lights. Not sure where the power for OD off indicator light comes from. Remove the four screws, two each in the cup holder and ashtray, pop off the dash cover, remove the two screws holding the switch, pop off the back of the switch. There's the bulbs.
