Engine/Transmission (1994 - 1998) Is there a scanner for the trans and engine?
2nd Gen Non-Engine/Transmission Bent Axle... How can I fix it?
Engine/Transmission (1994 - 1998) Fuel Filter sucking dry???
I am a new owner. I have a 100kmiles 95 4x4. It has been doing strange things as far as shifting. I changed the tps. It is some what better with the new tps. The trans temp light comes on some times, I am going change it on Saturday. At times the o/d light has come on by its self and won't go off until I turn the truck off. I have had it in o/d and it goes out of o/d out by its self. I thought if I had a scanner that checks codes for the engine and trans I could find the codes to determan what is going on. If you have any suggestions please help me out. Thanks Jack
its built into your truck. turn key on. turn off. turn on. turn off. and turn on and leave on. codes will flash out at you. but they mean much of nothing.
if the transmission either gets hot or thinks its hot, it may throw truck back into 3rd as a limp home mode.
this can be caused by a real fault such as a hot transmission. this can also be caused by circuit failures such as intermitant opens in the wires. an example would be hitting a bump and a loose connection looses contact. another example would be as the harness and engine warms up expansion and contraction causes it to lose contact.
this can also be caused by faulty sensors or other electronic hardware. if the temp sensor is going on the fritz it can give the pcm any number of faulty readings. same with the solenoids that control lock up and over drive.
with the intermittant nature of the fault, ones most likely to believe option number 2, poor connection that manifest itself only under certain circumstances.
instead of buying and replacing random parts only to get mad and blame it on the truck, do your self a free favor.
inspect the wiring harnesses that lead to the transmission. UNPLUG each connector. inspect for corrosion at the terminals or broken retainers on the connector. inspect the wires for cracks frays or breaks. follow the wires from the transmission (on the drivers side) up to the bulkhead/firewall. the will lead to the main harness that runs across the engine bay in the plastic loom. they continue behind the airbox/ac accumulator where you will find the main pcm harness connector.
i experienced similar problems, unplugged the transmission solenoid wires (3 pin connector drivers side transmission case) and plugged it back in. problem has not occurred since. at this time i had discovered someone ran a brand new single wire from the pcm pin 54 to the transmission, possibly due to a burnt factory wire.
you can completely bypass the factory temp switch by unplugging it and wiring in resistors. i dont have the schematics or details, but they float around here quite often.
the next thing to do is find out what your real transmission temperature is by installing an aftermarket gauge and a sender in the transmission pan.
Unplug the electrical connector to the trans temp sensor and put a 1K resistor in the connector instead and see what happens.
