Is this a HI output engine
Smarty question,.....timing vs. no timing
AFE's Dry Drop-In Air Filter?
"5. 9L L6 HPDI TRBO DSL" does that coding mean its hi output I thought it usually had ho after the description and I cant figure out in the vin number which number tells you what engine it has... .
Im guessing in that specific description "HPDI" means "High Pressure Diesel Injection" when its really supposed to be HPCR. What year is the truck?
2004 3/4 t laramie long bed auto Im looking at it to buy... . when I bring the vin up thats all it shows for an engine in the description...
Look on the engine tag and it'll tell you if you have the 305/555 engine or not. Sorry pics are with camera phone with bad light = not good photo.
unfortunatly I dont have the truck yet still in the dealing stages... . and its 40 mile away from me at the dealer..... Ill have to check Monday before I sign any thing because Im only buying if its a HO... .
Anything built after 04. 5 is only an HO. Cummins is only making one motor for all 50 states now. Just ask the dealer if it is a 04, or a 04. 5. If nothing else, it should provide you with some comic relief... .....
Just ask the dealer if it is a 04, or a 04. 5. If nothing else, it should provide you with some comic relief... ..... :-laf
Now that't funny. :-{} :) ;) :D :-laf :eek:
Good Luck
Cliff
Find out the build date. If it's after 1/1/2004 it's probably a 2004. 5 and if that's the case, it's definitely an HO -- probably a 325/600. But like the kind folks said above, you have to read the label on the valve cover to be sure.
Here you Go!!!
Body Style: DR7H42 Build Date: August 13, 2003 Hour: 22
Book: R Carline: X
Color 1: PR8 - Deep Molten Red Pearl Coat
Color 2: QS2 - Bright Silver Metallic Clear Coat
Engine: ETH - 5. 9L HO Cummins Turbo Diesel Engine
Transmission: DG8 - 4-Spd. Automatic 48RE Transmission
Sale Type: 1 - DIRECT RETAIL Last Odometer: 30,752 Miles on June 8, 2005
Sound like the one you looked at? The ETH is a 305/555 motor not a 325/600 but is awesome. Hope this helps. eg
I Have a Question
How did you like your HX35/40 Hybrid-16cm turbo and housing our trucks are similar and I'm trying to decide between your choice or a new HTB2 any input would be great. Thanks eg
CLAYTON said:
The SO's didn't have the 11. 5 real axle either... I think.
Mine is a SO/250hp/47RE build date 11/15/02 with no Calif emissions (Calif is SO/235hp), also it has the 11. 5 rear axle.
Tony
I loved it, the guy who apraised my truck almost lost it because I told him that it was built did he listen... noooo he about did a 180 in the middle of the road... in fact Im taken all of it off before I sell it 370 injectors ,turbo,aircleaner... .
