JField
Can the transmission be damaged when towing in OD even if the temperature stays low? My trans temp is being taken on the hot line out of the transmission. My towing speed averages about 60 mph and 1900 rpm. the temp ranges between 140 on level ground and rises to 180 on level ground on hot days. It peaks at around 230 on steep grades and when backing the trailer into the driveway. I have 4. 10s gears and the trailer is a 24 ft travel trailer approx. 5000 pounds. No modifications to transmission and it doesn't slip at this point.
TELL me what you guys think
Thanks,
JField
Thanks,
JField
