Is a weight distributing hitch really needed for a Cummins/long bed/quad cab ?
My truck, 4x4 long bed/quad (NV5600 360lb transmission) is rated at 6000 lb rear axle max, 5200 front.
Stock weight, 4500 front, 2700 rear.
With 12,000 lb bumper pull trailer, 1200 lb tongue weight, font axle carries an additional
(I am calculating ratio between ball to rear axle, and distance between axles)
FRONT axle: 60/160 x 1200lb= 450 lb LIFTED OFF the front axle without weight distribution, so front axle will see 4500-450=4050 lb.
REAR axle: 2700+1200+450=4350lb.
With 700 lb of passengers, the weight will be 70/160x 700 = 306 lb extra on front, and 394 on rear.
So the final weights are 4050+ 306= 4356 lb FRONT (844 lb reserve), 4350+394= 4744 REAR (1256 lb reserve)
Even going to the maximum 1500 lb tongue weight (15% of 10,000 lb trailer weight, per owners manual for class IV) ,
The FRONT is 4244 (956 lb reserve), REAR is 5156 lb (844 lb reserve).
Now, with a HEMI being 500 lb lighter on front axle, and a short wheelbase, standard cab, 4x2, yes you need weight distribution for stability.
I have to get to work, but if someone will do the above numbers for a short bed. It will benefit more from a W/D hitch.
