Hey Tailpipe fancy meeting you here LOL. And look, its Tommy. Anyhow, those pumps definately have the big possibility of having computer conflicts. I had some very knowledgable and educated folks from Bosche and Cummins head office inform me off the DC ECM program being very poor. Heck, its just too long to type again so I'll go over to the H/campers site and copy/paste... BRB
I have a lot of experience with this pump... I am on my 4th. the Cummins
engineers I spoke to while dealing with this problem said that the problem that
was/is causing the failures was/is the DC ECM program. Heres what it does. At
2100 rpm the ECM recognizes too much load and starts to derate the fuel... by
the time your at 2750 RPM it is derated by 55%! This was DC's way of saving the
drivetrains! Bosche and Cummins warned against it for a few reasons. 1] The
rated power will not be produced with this ECM program. I know of several
people including myself that have proven the low power with dyno's and
performance tests of 45-80 mph [5th gear] as required by Cummins. A good
time is 20 seconds... Lots are getting 34 and higher. This is not just the 98. 5's
and is starting again with a batch of late 99's. There is one at my dealers right
now and 3 folks on the TDR have posted problems in the past few days.
2] When the ECM starts to derate fuel, you push the throttle more to get the
power... reducing power even more because the fuel is being cut back. Cut
back the fuel and you lean out the pump... lean out the pump and you have
metal on metal. FAILURE.
My first pump was shredded inside and Bosche told me directly that the
leaning out was the culprit. Bosche also said do not replace a failed pump with
a pump that does not have the 'R' at the start of the part number. The 'R' is for
remanufactured and Bosche said it is upgraded internally to handle the
running leaner.
My 2nd and 3rd pumps had no 'R' but this 4th one does. So far so good and its
got close to 40K on it.
Also, why do you think the uprated ECM came out for the manual trans trucks?
Cummins wanted to save face maybe? I really think DC screwed up at our
expense after all the info I gathered from very reliable sources. Some nerve
trying to charge an addtional $1,000. 00 or more for what we should've had in
the first place.
There is a wait of up to 6 wks to get a pump! Most dealers are robbing trucks in
stock to get folks on the road.
I can get injectors and pumps... cheap. A pump was around 1800 USD. 275 HP
injectors... 375/set.
I forgot to mention... the majority of these failed pumps are a result of the fuel
being derated while under load like pulling a trailer and they do not have to be
real heavy weights.
But with saying that I recently read on here and over at that other site that it does not matter about the 'R' at the start of the part number, Sheesh. I sure do not wish this hassle on anybody but maybe... . MAYBE we'll have some strength in numbers if it keeps spreading.
Sorry for the long post.
SCOTT
LIFT IT FLIP IT OR...
RAMIT!
[This message has been edited by scott1 (edited 10-02-1999). ]
