If you happen to remove your lift pump and move it somewhere else or install a better pump and dont need the bracket you might be able to remove it to clean up the engine area a little more.
There was some info here that stated if you removed the bracket it would uncover a passage that used to be cast into the block for the 12V lift pump arm to contact the camshaft lobe. Thus oil would shoot out this passage if left uncovered.
Recently I read some posts where some took them off to only find a solid block and no passages. Well curiosity got the best of me and I took mine off. Mine is solid and the four threaded holes for the bracket bolts are not thru to the inner engine. This kinda made me happy as that bracket was always staring at me with no purpose and looked kinda strange just sticking out for no reason.
The bracket itself has two threaded holes in it which wiring harness clamps attach too. But the harness is so stiff right there I can't see how losing them is going to harm anything. My harness is still tight in place.
Just thought I'd throw this out in case anyone wanted to get rid of theirs. But dont be suprised if you have a passage. Some did... some didn't. Kinda reminds me of the ISB improved gear case... some 24V's had them while others didn't.
